Does not get power then does get power
JANAE ALYSSA PEARCE
  • 1999 DODGE DURANGO
  • 4WD
  • 225,000 MILES
So my truck will not start and has no power at all. When I open my driver side door it clicks. Which I know that it means the battery is drained. So I called a friend to get a jump start while waiting for her I was looking at the battery (brand new 6/17) and I opened my driver side door and my door lights came on so I got power back. So I just decided to see if it would start. (About five minutes later is when I tried this) Put my key in the ignition and it stuttered but started. What could it be?
Tuesday, December 5th, 2017 AT 4:48 PM
CARADIODOC
  • 33,916 POSTS
Follow the smaller battery positive wire to the under-hood fuse box and be sure that connection is clean and tight. Follow the smaller negative wire to the body and be sure that connection is tight and not rusty.
Tuesday, December 5th, 2017 AT 6:25 PM
JANAE ALYSSA PEARCE
Thank you so much. I will do that in the morning.
Tuesday, December 5th, 2017 AT 7:00 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
It sounds like it could be a battery with an intermittent short issue. Try this test to see if it passes.
Cheers, Ken
Thursday, December 7th, 2017 AT 7:33 PM
JANAE ALYSSA PEARCE
Doesnt have power to the dash which is causing it to not start. The alternator is good n im pretty sure the starter is good. The battery is good. Im just puzzled why it wont start. N then when I try to turn it over I can hear the starter click then that stops and there is a clicking sound coming from under my glove department on my Passenger side. What could it be?
Thursday, December 14th, 2017 AT 5:08 PM
CARADIODOC
  • 33,916 POSTS
Everything you're describing I've read before when people have a bad or run-down battery. Remember, a bad electrical connection can mimic a bad battery. Did you check the two connections I suggested? Those cause a lot of trouble on all brands of vehicles.
The way to find this is to use a digital voltmeter and start right at the battery posts. You must find 12.6 volts if the battery is good and fully-charged. If it's less than that, let me know. Next, a bad connection will show up with voltage readings only when current is trying to flow through the circuit. Turn the head lights on, even if they don't work. At least current will be trying to flow. Now move one of the meter leads from the battery post to the cable clamp on that post. The reading should be the same. Now move the other probe from its battery post to that cable clamp, and again, the reading should be the same. If you find the reading drops even a little when you move to a cable clamp, that connection needs to be cleaned and tightened. A drop in voltage that shows up when two tiny head lights are trying to work indicates a connection that will never let enough current through to run an extremely high-current starter or an entire electrical system.
If no problem was found up to this point, move the probe from the negative cable clamp to a paint-free point on the body. If the voltage reading drops, suspect the smaller wire bolted to the body. Now move the other probe from the positive cable clamp to the under-hood fuse box where the wire is bolted, but to be accurate, touch the probe to the stud or the metal tab going into the fuse box, not to the terminal on the end of the wire. This is the connection where most problems occur. Often you'll see a tiny spark when wiggling that wire.
Thursday, December 14th, 2017 AT 5:58 PM
