Engine will not stay running
180,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
GABE BEAVERS
Stalls and have to push gas pedal to get it to start.
Mar 11, 2022 at 11:05 PM
  • 110,251 POSTS
If you have to press the gas pedal, that is usually an indication of a flooded engine. Depressing the throttle turns off injectors and opens the throttle plate to allow the max amount of air to enter.
Two things. First, I need you to scan the computer to see if there are diagnostic trouble codes stored. This has an OBD1 system and doesn't require a scanner to retrieve codes. All that is needed is a short jumper wire or even a paper clip. Here is a link that explains how to do it:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Next, if there are no codes that are relevant, we need to check the fuel pressure to see if it is too high due to a faulty regulator. Here is a link that explains how it's done:
Try these things and let me know what you find.
Mar 12, 2022 at 2:23 PM
