Trickle charger/battery tender
140,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
GOLDENDAVE
  • 51 POSTS
I drive my vehicle maybe once or twice a week at most for 30 minutes at a time and have had an issue lately where the engine won't crank unless, I end up having to turn on the headlights for 15 or so seconds to get a current flowing. The battery is from Honda and is just about 4 years old.
I took it took it to my local Honda dealer where they ran a full electrical check and determined that everything is fine, but the battery needs to be recharged. Their solution: be sure to drive it more frequently or get a battery tender.
This makes sense considering how infrequently I drive it but the question I have is, where do I even start with choosing a battery tender? Is there a certain type that works for smaller cars or are they all one in the same? Additionally, would buying a new battery and driving the car just as infrequently result in the same issue (no crank unless I turn on the headlights)?
Thanks in advance.
Nov 10, 2019 at 11:22 PM
CARADIODOC
  • 34,403 POSTS
As a battery ages, the lead gradually flakes off the plates, causing it to be less able to supply the very high current needed by the starter. I have a suspicion by turning on the head lights, the relatively low current flowing through the battery is causing it to warm up inside. Car batteries produce their current through a chemical reaction, and those always become more efficient as temperature increases.
To add to the misery, all cars with computers draw a little current from the battery all the time to keep their memories alive. Unless specified differently by the car manufacturer, the industry-standard is a good, fully-charged battery will still be charged enough to start an engine that has been sitting for three weeks. Most will go a little longer, but three weeks is what is expected.
Thirty minutes of driving should be sufficient to bring your battery back to full charge. It's only when a battery is completely dead, as in when the head lights were left on for a couple of days, that 30 minutes would not be enough. It can take over 15 minutes on a charger, or driving after getting a jump-start, before the battery starts to take a charge. That is when the electrons start to get absorbed into the plates.
The next factor is one of the requirements for any generator to work is part of it has to be moving in relation to the other part. That's where the drive belt comes in, and speed is a variable. At idle speed, generators are very inefficient, so any time you're sitting at a red light, very little charge is going back into the battery. If you're driving 30 minutes at highway speed, that should be sufficient to recharge the battery.
The problem likely stems from a four-year-old battery that has only perhaps 20 - 30 percent of the storage capacity as a new one, plus the very short time it has to recharge, plus the fact that a car this new has dozens of computers with memory circuits that all draw some current from the battery at all times. If any one of those things was removed from the equation, there's a good chance you wouldn't be having this problem.
If you prefer to avoid potential problems before they occur, you might consider buying a new battery now. The battery manufacturers know how quickly the lead flakes off the plates. Typically that takes five years for the lead to build up in the bottom of the case, then it shorts out one of the cells, and the battery must be replaced. They usually provide a five-year warranty since they know that is how long the battery should last. With a new battery, it is going to be able to keep those computer memories alive and still remain charged enough to crank the engine. Also, since it's not fully run down, once you start driving, the battery will begin recharging right away, not 15 20 minutes later. That means your 30 minutes of drive time will likely be sufficient so you won't have to bother with the head lights like you do now.
If you like to take chances, or in my case, get the last ounce of life out of a car part, the battery tender might be the better solution. That should get you the last year of life expectancy out of your battery, but you can still expect that battery to fail within the next year or so. No battery tender will prevent that. Basically all these do is provide a very small current to make up for what is being drawn by the computers' memory circuits.
Most of these plug into the cigarette lighter or power outlet socket, but this presents another problem. They will only work if that outlet remains live when the ignition switch is off. Those outlets turn off on most import car models. To see if that applies to your car, plug in a device that has some type of indication if it is powered up or turned on, then see if it remains on when you turn the ignition switch off. If it stays on, you can use that socket. If it turns off, you'll need to buy a battery tender that clips right to the battery cable clamps. To further complicate this and add to the frustration, some power outlet sockets turn off, but they remain on for five to ten minutes after you turn the ignition switch off. That type of socket also will not work for this problem. You have to be sure the socket stays on all the time.
Some people use a very small battery charger for this purpose, but they could over-charge the battery when left on too long. That would eventually boil the water out of the acid, causing the battery to be even less-able to start the engine. Better to buy a product specifically designed for cars that sit for long periods, and that don't have any other electrical problems.
Harbor Freight Tools has two types of battery tenders. If your car sits outside, you can use a solar-powered unit. Most of these plug into the cigarette lighter, then the charger sits on the dash. If the car sits in a garage, you'll need a unit that plugs into an extension cord. Those usually clip to the battery cable clamps. You can also find these at Walmart, farm and home stores, hardware stores, and any auto parts stores.
Nov 11, 2019 at 8:46 AM
GOLDENDAVE
  • 51 POSTS
Thanks for the information, it was very helpful.
One follow-up question: knowing that Honda batteries only have a three year lifespan is there a specific aftermarket battery that's just as good, if not better, that you'd recommend?
Nov 11, 2019 at 11:14 PM
CARADIODOC
  • 34,403 POSTS
I've never heard that of Honda batteries. Most replacement light truck batteries do come with only three-year warranties because of the harsh environment they live in and the excessive bouncing they experience. That knocks the loose lead off the plates faster, so it can be expected it builds up in the bottom of the case faster and will short one of the cells faster. Just about every replacement car battery has a five-year warranty, but a few have six-year warranties, and a few manufacturers offer an inexpensive replacement with a four-year warranty. Those are intended for people making their buying choices strictly on price and not on quality. These batteries are lighter because they have less lead on their plates. They're popular for people planning on selling the car but it needs a new battery first.
Every brand of battery has people who love them and those who would never buy another one. I've had good luck with CarQuest batteries in the past.
I can offer a few other suggestions that are better than buying an expensive battery at retail prices. The first is to visit one of the larger salvage yards. The small ones get the worn-out, high-mileage, low-value cars, and those owners often keep the battery if it is still good. The larger yards buy smashed cars from insurance companies, and those are often only one or two years old. Some sell the batteries for as much as $30.00, but you'll usually find them for around $19.95. You'll typically only get about a 90-day warranty from the yard, and then, if it does fail within that time, they'll just trade it for a different battery. That one would just ride out the remainder of the original 90-day warranty.
For about the last five or six years, I've been buying "reconditioned" batteries from a local battery store. At first they told me those could be batteries that had simply been sitting on the shelf for over a year, and they wanted to get them sold. These cost $30.00 plus the trade-in of the old battery. To make this even better, they were paying $5.00 for every additional "core" battery, so I took in seven altogether, then the new battery didn't cost me any cash. Today the cost of one of these reconditioned batteries is $35.00, and they pay $7.00 per core, so it takes six old batteries to get one new one. Even when you don't have any extra old batteries, $35.00 is a real good deal for a new battery.
Now I've also learned these could be batteries that someone bought, thinking it was going to solve their problem. When they figured out they had misdiagnosed the problem, they want to return the battery for a refund. As far as the store is concerned, that is no longer a "new" battery, and can't be sold as such, but it is still good, so they call it a "reconditioned" battery and sell it at a reduced cost.
I've bought at least eight batteries this way in the last few years and haven't had trouble with any of them. One even went into a skid steer with a diesel engine that's hard to start in cold weather. Two "deep cycle" batteries run a car radio display at an old-car show swap meet every summer. The last one went into my 2014 Dodge truck. It sat all last winter and I let all its computer memory circuits drain the original battery. Not sure if it froze, but in the spring it wouldn't crank the engine. This was a special "absorbed glass mat", (AGM) battery, but they actually did have a reconditioned one available. For my old one, however, they refused to take it in trade unless I took it home and charged it at a slow rate for a minimum of three days, then they'd take it if it tested "bad". This is an unusual characteristic of these batteries, but they were right. After slow-charging for a week, that battery is still working fine two years later. Most other batteries can typically be slow-charged enough in a few hours to get an engine started.
For another exciting chapter to this story, here's a link to an article about how your battery works:
https://www.2carpros.com/articles/how-a-car-battery-works
This article covers replacing the battery:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
It makes mention of the electrical ratings, but doesn't explain them. For the most part, domestic car manufacturers do not cut corners on their batteries. You get a lot more battery than you need for the application. Import manufacturers tend to put in just enough battery to get the job done, so when choosing a replacement, at a minimum, you want one at least as strong as the original. With domestic vehicles, it is usually okay to buy one that is smaller, electrically, than the original battery. That's what I did with my truck, and it's performing just fine.
The first two things to look at are physical characteristics. The outside of the case has to be of the correct dimensions to fit in place, and it can't be too high that the posts will be hit by the hood. Some cars have enough room to accommodate a battery that is an inch or two longer, but that could mean you're buying more battery than you need, at a wasted higher cost.
Next you have to look at how the battery is held in place. That's important to prevent it from bouncing excessively, which will knock that loose lead off faster and hasten the eventual failure. Some batteries are held down with a metal or plastic strap that sits on top of the battery. Some use a small metal plate that sits in a groove near the bottom of the case. A lot of replacement batteries can be bolted down either way. If you're buying the battery from a salesman, he will select the right case size and style for your car.
There's basically two electrical ratings to look at. The main one is "cold cranking amps", (CCA). Some batteries list their "cranking amps", but that rating is not standardized between manufacturers. Cold cranking amps is a measure of how much current the battery can supply, at 0 degrees Fahrenheit, while maintaining a minimum of 9.6 volts for 15 seconds. That is standardized, so it is accurate for comparing batteries from different manufacturers. The common original batteries for import cars is from 350 to 500 CCA. Even my 1980 Volare came with a tiny 325 CCA battery, and it handled the job just fine for over five years. Most domestic cars today come with batteries of around 600 to 750 CCA. Anything higher than that is basically a waste because that kind of power just isn't needed. In fact, if you were to drop down to a 500 CCA battery for those applications, it would work perfectly fine. You can find replacement batteries as high as 850 to over 1000 CCA, but for a car, that's just showing off. Those are good choices for trucks with diesel engines. Those trucks usually come with two batteries because it takes a real lot of cranking power to get them started in cold weather.
The second rating is the battery's "reserve capacity". That's a measure of how long it can run a light load, such as the radio, before its voltage drops to a specific value. I'm not aware of any standardization for that rating, so it's more for comparing two or more batteries from the same manufacturer. This rating has little value to car owners who just need it to start the engine.
I should add a paragraph, for the benefit of others who might be researching this topic, that some car manufacturers have purposely designed-in tricks to make their dealers money. Volkswagen is one of the most noteworthy, along with Audi, BMW, and I've heard, GM. On some of their models, simply removing a battery cable, whether to replace the battery, clean the connections, or for some other service that requires this to be done, will cause multiple computer to lock up. The only fix for that is to tow the car to the dealer where they can unlock them. With some VW models, we've heard the horror stories where even if the engine starts, it will only idle, and won't come out of "park". Pressing the accelerator pedal has no effect on engine speed. The car has to be dragged out of the shop and onto a flat-bed truck for the trip to the dealership where they will use their proprietary equipment to unlock the computers. Two of these that we learned about in a very high-level training class for mechanics from independent repair shops cost those owners over $950.00 by the time the cars were driveable again, . . . just from disconnecting the battery cable.
To avoid this problem, there are all kinds of "memory saver" devices on the market. They get connected just like your battery tender, but they supply a little more current to keep all the computers alive and unlocked. The only things to watch out for is it doesn't accidentally become disconnected, and you can't open a door or turn on the ignition switch. Doing either of those will cause more current to be needed than those devices can supply. The battery installer used one on my truck even though the only memory it saved was the clock on the radio. He just wanted to be safe.
My last comment of value has to do with the "juicy rings" or sprays some sales people will try to sell you. Those have no value for most of us. After ten years at the dealership, and watching my own batteries, what I finally figured out was any battery that had plenty of life left in it never developed the characteristic white corrosion around the posts, so those chemical treatments weren't necessary. And, when you did find that corrosion, that battery was going to fail naturally within six months, and there was nothing you could do to prevent that. Cleaning the connections of that corrosion can solve intermittent electrical problems, but it's not going to extend the life of the battery.
It appears that as the lead flakes off the plates over time, which can't be avoided, there is less and less on the plates, yet the charging system keeps right on charging the battery as if it was at full strength. With the same amount of current flowing through less lead to absorb the electrons, those plates get hotter than normal, and that tends to boil the acid. The bubbles that creates pop right under the top of the case, then the liquid deposited there migrates to the terminals where they come through the top as the posts. It's that acid that causes that corrosion. Good batteries have more lead in their plates to absorb the electrons, so that current flow has less tendency to heat up the acid and cause those bubbles to form. There's nothing for those juicy rings to neutralize. In fact, even the chemical in those rings can find its way between the posts and cable clamps and cause intermittent problems. The best advice is when you finally see that white corrosion building up, expect to need a new battery in a few months.
Nov 12, 2019 at 9:35 AM
GOLDENDAVE
  • 51 POSTS
Thanks for the information.
I may have misspoke regarding The expected lifetime of Honda’s batteries. Everything I’ve found says they’re good for 100 months, not 36. And since this battery was most recently replaced in December of 2015 it’s not quite to 100 months yet.
The quick fix does seem like a new battery. Like you said, to each their own, when it comes to battery brands. But is there any reason I shouldn’t get a replacement OEM battery? Cost isn’t really a concern, I just don’t want to have to go through this same exercise in several years, so something that lasts as long or longer would be ideal.
Thanks again for the detailed information, I really appreciate it.
Nov 12, 2019 at 9:51 AM
CARADIODOC
  • 34,403 POSTS
Honda doesn't manufacture their batteries. They buy them from a battery manufacturer that puts the Honda name on them. Since all the raw materials have to be imported, the car manufacturers don't put any more into anything that isn't needed.
You likely will not get the same battery from the dealer. Those installed at the factory are a special run as requested by the engineers. Replacement batteries are manufactured as needed, and they don't want to build hundreds of different designs that they have to keep in inventory. Instead, they'll build a one-size-fits-many battery that is equal to some original batteries and better than most it is replacing. Just about any battery you can find for your car will be stronger than the original one, but the dealer's will be closest to original. The only thing that's different is the dealer will charge a lot more, but you're not getting more value for your money.
At least stop in at a battery store and listen to their sales pitch. If you're not convinced they have some better option or lower price, go back to the dealership. At either place they'll find the right battery and they'll install it for you. The dealer will usually charge for labor to install a battery. Battery store people do it for free, and they'll usually perform a basic charging system test to insure there's no other problems.
Nov 12, 2019 at 10:24 AM
