Transmission swap
190,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
BRIANAUSTINX
Can I use a 1980 aod transmission in my 1991 F150? Came from a 2wd, same 14 bolt pan.
May 5, 2020 at 6:21 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
As long as you have the detent cable it will work, one thing to check is to make sure the tail housing is the same length as yours otherwise you'll have to change the driveshaft. One of the nice things about the AOD is that everything is regulated by the cable and the governor so there is no electrical or vacuum lines to worry about other than the neutral safety switch.
Mar 24, 2021 at 6:38 AM
BRIANAUSTINX
Thanks a lot Dave, I really appreciate it man.
  • 55,732 POSTS
MOTOR MASTER is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
