transmission swap ??
POOLGOD27IA
I have a 94 ford f150 4x4 has a 5.oL automatic with push button OD, Transmission went bad I thought it was a E4OD so i bought one, well dropped the old transmission out and found out it was a AOD-E, so know I'm wondering if the E4OD transmission will fit in the truck since i already bought it and if so what problems will i run into, or will have to change to make this work???
Aug 11, 2007 at 5:32 PM
INDYUKE
  • 416 POSTS
You probably won't have to change much. The E4OD transmission is a better transmission I think. It should bolt right to your engine just fine. You might have to change the location of the rear tranny mount and change out the computer for one that is calibrated for an E4OD rather than a AOD-E, or have the dealership reflash the computer thats already in there.
And you may need to have a machine shop change driveshaft lengths. Let us know.
Aug 14, 2007 at 6:03 AM
