Transmission slips only once when it is cold
102,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
DODGEDAKOTA00
It feels like my transmission is slipping when I first pull out of my drive way and give it a little gas. It has been cold where I live about twenty degrees F average. when the truck is cold the transmission will slip only once the rpm's spike a little and the truck jerks forward it only does it once when your first drive. After that it shifts fine. The fluid was low and I added a Quart of ATF +3 which is what Chrysler recommends. the fluid is now right in the middle of the okay marks. it is a four speed automatic transmission. any help to what this could be would be much appreciated.
Jan 10, 2018 at 4:37 AM
  • 55,748 POSTS
It sounds like you have a filter inside the transmission that is plugging up. I would do a service first to see if that helps which it should.
Here is a guide to help you see what you are in for when doing the job:
Also, we should run the codes to see if anything comes up.
Cheers, Ken
Jan 11, 2018 at 6:59 AM
