transmission shift problems
265,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BERNIE OBREMSKI
this just started happening drove to store came out started the truck put it in drive slowly eased the gas and the truck was very slow to take off. so, i stopped and turn it off and turn it back on shift into drive and go home like normal. then it does the same thing two days later when i get home to check all the wiring under the hood disconnect the fuse box look at all connectors for broken or exposed wires, see nothing of the sort put everything back together and have no problems for about 8 days, then it starts all over again with the slow take off when put in drive it comes and goes.
May 18, 2022 at 6:09 PM
  • 110,248 POSTS
Have you checked the transmission fluid level and condition? Do me a favor. Take a look through this link and let me know if anything is helpful:
Let me know. Also, let me know if the check engine light is staying on while the engine is running.
May 19, 2022 at 12:55 PM
