2002 Chevy Avalanche
DRYLANDER
  • 2002 CHEVROLET AVALANCHE
  • V8
  • 4WD
  • 140,000 MILES
I have a 2002 avalanch and cant seem to find the problem. When I start the truck I dont get any gauges, I dont have any first or fourths gear. The problem has gotten worse, I used to be able to restart and the problem went away. If I manually put the car into second it will go in second and I can shift to third.. The gauges will come back but I still am stuck in third gear. And sometimes it runs perfect. Any answers
Tuesday, May 18th, 2010 AT 6:47 AM
HMAC300
  • 48,601 POSTS
Check your battery and ground connections. Your battery may be in poor shape causing this. If it doesn't straighten out have a trans guy run a scan to see if somehting is wrong with the trans. You may have two seperate problems.
Thursday, May 27th, 2010 AT 8:04 PM
DRYLANDER
It was the ignition switch
Tuesday, June 1st, 2010 AT 6:08 AM
