2004 Chevy Avalanche transmission
2004 CHEVROLET AVALANCHE
75,500 MILES • V8 • 4WD • AUTOMATIC
ANNE STEWART
2004 chev avalanche with towing package, and trans cooler. After driving about 3 wk ago I stopped at stop sign, and when I took off trans acted like it was in 4 wheel drive. Checked the panel and it was 2 wheel drive. Felt like it wasn't shifting. Pulled over and stopped and started in 2 nd gear, then to 3rd and then to drive and it shifted roughly. Pulled over again shut car off waited for a minute and stared car again and ran fine and shifted perfect. Ran fine for a couple of days then happened again, shut car off for 30 seconds and back on and again fine. No dummy lights or messages on car. Checked the trans fluid it was very dark, a little dirty, and in cold zone instead of hot zone. Went to dealership had trans flush, new fluid, and new filter. Before I got out of parking lot check engine light came on with no problems shifting. Took it back to dealership who stated codes stating tcc and 2-3 shifting selnoid are bad and put on full electrical check that further stated ignition switch not giving power to above selenoids. Is this possible. How to tell if selenoid bad or ignition swith bad. Have had minor issues over a year ago, 1. radio went out replaced fuse and fine and fuel gauge sensor went out. Anne S.
Apr 1, 2008 at 7:33 AM
DENNYP
  • 1,824 POSTS
If the ignition switch fails on the trans circuit, it will cause a loss of power to all transmission solenoids. It will also default to a higher range gear for takeoff. The ignition swtch failure is very common. Get it replaced and you should be ok.
Apr 2, 2008 at 2:37 PM
