Transmission radiator bypass
150,000 MILES • V10 • 4WD • AUTOMATIC
BERNIECE BRUCE
Can i bypass the transmission radiator in a 1998 dodge ram 2500 V1O?
Mar 20, 2018 at 7:35 PM
Good morning.
Yes, you can but you must install a cooler and place it in front of the radiator. the transmission cannot last without having a cooler for the fluid. you can get one at a parts store as they sell a variety of different coolers.
Mar 20, 2018 at 9:11 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Why would you want to bypass the cooler?
Is the cooler not inside the radiator?
If the cooler is broken, transmission fluid and coolant has mixed and both the cooling system and transmission will have to be flushed out and new fluid put in as well as fixing the broken oil cooler.
Spectre premium has a radiator CU1555 and it is sold at rockauto for $165.00. I am sure there are other places that sell it as well.
https://www.rockauto.com/en/parts/spectra+premium+/+cooling+depot,CU1555,radiator,2172
Mar 21, 2018 at 1:19 AM
