transmission proplem
2008 KIA SORENTO
300,000 MILES
ABDULLAHABBAS
I have a car Kia Sorento 3.3 liter 2008 model
Cut 320,000 kilometers and transmission problems in knowing that I have the automatic transmission and manual transmission.
Transmission does not respond in the reverse switch most of the time and delayed Valtbdel with the change using Altbtonak system (manual change) there is no any problem
When examining the car does not show any computer problem
Apr 17, 2013 at 2:33 AM
HMAC300
  • 48,601 POSTS
check trans fluid first then scan for codes, have a trans guy pressure chek it
Apr 17, 2013 at 6:46 AM
ABDULLAHABBAS
hi frined
I change gear oil and I do computer program for the gare but still problem
what to do then????????????????
Apr 19, 2013 at 9:00 PM
HMAC300
  • 48,601 POSTS
do what I said you need to scan for codes to find out what is wrong with transmission
Apr 20, 2013 at 8:15 AM
ABDULLAHABBAS
sorry but i dont know how to do scan code?
and where can i go to do this action?
i weant many car repaire shope and i ask them to do scasn code for the gear
they answer they dont know how to do scan code
Apr 20, 2013 at 9:58 PM
HMAC300
  • 48,601 POSTS
as I don't know where you are most repair shops should have a scanner for cars it plugs in and you read the code to find out what is wrong. I fnot you will have to find aplace t hat does it.
Apr 21, 2013 at 5:53 AM
ABDULLAHABBAS
thax for help me friend
iam in UAE most work shope here not profissonal
can u tell me the technical name for this test
i will go to dealar and told them i want do this test
Apr 21, 2013 at 6:16 AM
HMAC300
  • 48,601 POSTS
just tell them your problem, it will need to be scanned for codes and a transmission guy will have to look at it.
Apr 21, 2013 at 7:24 AM
