Car does not drive forward just reverse
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
O.W. LATHAN
car will go in reverse but not drive (forward).
Jun 23, 2020 at 11:46 AM
STEVE W.
  • 15,401 POSTS
This may sound like an odd thing but I would remove the battery and have it load and voltage tested, BMW's can do some odd things if they have any voltage issues. Did this just suddenly happen or has it been acting strange for a while? When was the transmission fluid serviced last? Internally a bad pressure regulator can do this as it causes seal failures on the A clutch. That leads to a rebuild.
Jun 23, 2020 at 1:03 PM
