1992 BMW 525i check gearbox oil
EAANDERSON
Transmission problem
1992 BMW 525i 6 cyl Two Wheel Drive Automatic
Where do I check my gearbox oil?
How do I change the gearbox oil?
Feb 5, 2009 at 3:11 PM
DOCHAGERTY
  • 9,606 POSTS
On models without a dipstick, there is a filler plug on the side of the transmission, on the right side on the body of the tranny. It is checked with the engine running. To service the tranny, the pans both need to come off and gaskets cleaned and filter replaced. It takes Dexron ATF. There is no drain plug, you just pull the pans.
Feb 5, 2009 at 4:51 PM
