Vehicle will not go over 20 MPH?
2009 FORD ESCAPE
155,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
BREANNAMICHELE126
I'm able to turn one car. I'm able to shift gears, but when I pressed on gas pedal car will not move or go over 20 miles per hour.
Sep 26, 2021 at 4:08 AM
This sounds like you are in limp mode.
Here is a guide that will help talking about this:
https://www.2carpros.com/articles/reduced-power-limp-mode
What we need to do is start with pulling the codes and finding out what is there.
The most common causes of this are sensor issues. It could be an airflow sensor or a transmission sensor but at this point we are just guessing until we get some more info.
This is why we need to start with checking the codes and finding out what is there and go from there. Thanks
Sep 26, 2021 at 5:33 AM
