Transmission oil pump
130,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
CHRISTY ELKINS DEEMS
Upon the vehicle cranking with no problem I hear what I think is the transmission oil pump making a whining noise. If it is making the noise I can put in gear and ride. However I may get a mile or five miles down the road and I roll to a stop. I can get out and tap on the transmission pump a few times get back in crank and ride again for another mile maybe five to repeat same process.. Can someone please guide me in the right direction as to what could be the cause? Am I going to need a new transmission completely? Any help would greatly be appreciated. My mom and I only have this way of going and my dad just passed away last month so it is up to me to take care of and fix things myself now. Thank you in advance for any help.
Nov 8, 2018 at 12:28 AM
Good afternoon.
The reason for the noise from the pump is due to a lack of oil. I would start by changing the trans oil and filter. That may take care of the entire issue.
Beyond that, the pump may have failed which will indicate a transmission overhaul.
Nov 8, 2018 at 2:20 AM
RENEE L
  • 1,260 POSTS
Dear CHRISTY ELKINS DEEMS,
Our deepest condolences for the loss of your dad.
Sincerely,
The 2CarPros team
Nov 9, 2018 at 5:15 AM
