Transmission
160,000 MILES • V8 • 4WD • AUTOMATIC
TIESHA HOPKINS
hello, my husband had a accident which the damage was more in the front of the car. I got the front repaired but now I tried to move the car and it will not go into gear. Once it is out of park it will not go into reverse or drive. when i put it in drive and really idle the car it will jump like it is trying to go.
May 29, 2017 at 2:59 AM
  • 55,612 POSTS
It sounds like when you had the repair work done the radiator has replaced and the transmission was not refilled. Please check the transmission fluid level.
Cheers, Ken
May 31, 2017 at 8:50 AM
