transmission not shifting from first gear
160,000 MILES • 3.5L • 4WD • AUTOMATIC
RONNIIE BOY
i changed fuel pump and mass airflow sensor then reset computer now it does not shift and revs up when changing shifting positions.
Aug 12, 2020 at 9:26 AM
Good morning,
What were the codes that were set for you to replace those parts?
Was this issue present prior to the repair?
Aug 12, 2020 at 9:08 PM
RONNIIE BOY
didn't get codes checked i just went by things i read online.
Aug 12, 2020 at 10:25 PM
Okay,
Is the check engine light on?
Again, was this issue present before those repairs?
The transmission main sensor is the throttle position sensor. That sends a signal to the ECM where the fuel pedal is at and load and the ECM adjusts the time the transmission shifts.
This is why I am asking about codes. If the sensor was an issue, it should code. You can have the system read for free at a parts store.
I attached the location and the wiring diagram of the TPS for you. Do you have a voltmeter to test for voltage?
Aug 12, 2020 at 10:35 PM
RONNIIE BOY
no, it didn't do that before. the throttle position sensor was my next step i wanted to ask to be more sure.
Aug 13, 2020 at 12:17 AM
I would verify voltages to the sensor before replacing the sensor.
Aug 13, 2020 at 12:21 AM
RONNIIE BOY
i had taken sensor off to make sure it wasn't dirty could it be on wrong?
Aug 13, 2020 at 12:54 AM
No, because if it was, it would set a code for it.
Aug 13, 2020 at 12:56 AM
