Transmission has trouble shifting, then surges when it does shift
2005 DODGE TRUCK
261,000 MILES • 5.9L • TURBO • 4WD • AUTOMATIC
CATDW20
We have a Dodge Cummins, 2500. It is having trouble shifting into second, going past 2,500 before it finally shifts. Once it does shift, it seems to surge, then RPM's go up again then will finally shift. Any thoughts on what's causing this?
Jun 22, 2019 at 8:08 PM
  • 54,837 POSTS
This sounds like you have a turbine shaft speed sensor that sounds like it is not working. To be sure lets run the codes to see what comes up.
Jun 24, 2019 at 3:57 PM
