2005 Dodge Truck Won't Start
J#
  • 2005 DODGE TRUCK
  • 6 CYL
  • 25,000 MILES
Diesal, Start's in the morning, but as the day goes on it won't start. Crank's over but won't fire. Startes on either. No codes, 8psi fuel presure between filter and pump. Sometimes starts fine. Help!
Wednesday, October 8th, 2008 AT 5:41 PM
  • 109,885 POSTS
Hi:
I have to do more research, but 8lbs doesn't sound right to me. I was thinking more like 15. I will try to find it for you, but if you know someone at the local dealership, they may get you a quicker answer.
I'll let you know what I find. Let me know if you find out before I do. Finally, when you checked the fuel pressure, was it during a time the truck wouldn't start?
Wednesday, October 8th, 2008 AT 9:04 PM
J#
  • 5 POSTS
I think I seen 8-10 someplace. It will hold 8-10 during cranking. It will go below 5 during heavy acceleration Run's good after starting
Wednesday, October 8th, 2008 AT 9:19 PM
  • 109,885 POSTS
Hi:
According to google, 10 PSI is normal. Now I have a stupid question for you. You said you checked the pressure between the pump and filter. Does it loose any after the filter? I realize that you most likely already know to check the filter, but since I'm not there, I don't want to assume.
Wednesday, October 8th, 2008 AT 10:50 PM
J#
  • 5 POSTS
I finally got a code P251 Fuel control relay. But I can't find it? It not in the fuse panel like it's suppose to be?
Thursday, October 9th, 2008 AT 9:29 AM
  • 109,885 POSTS
Hi:
check under the hood in the power distribution center.
Thursday, October 9th, 2008 AT 10:23 AM
J#
  • 5 POSTS
The book say's it's there but it's not on my truck
Thursday, October 9th, 2008 AT 11:17 AM
  • 109,885 POSTS
Hi:
I'm sorry, but I'm not there to look. Therefore, I suggest you take it to a mechanic for the location. I wish I could help you better, but the miles between us stops that.
Good Luck,
Thursday, October 9th, 2008 AT 11:28 AM
J#
  • 5 POSTS
Loose Cross Tube !
Tuesday, October 14th, 2008 AT 11:32 PM
