2005 Dodge Truck stall out at red lights
2005 DODGE TRUCK
40,000 MILES • V12 • 2WD • AUTOMATIC
BILLY1959
The truck will just stall out at red lights or trying to pull out of a drive way wainting your turn and gives no warnings or warning lights. why?
Sep 20, 2008 at 8:25 PM
RENAUDTN
  • 636 POSTS
Check your IAC motor make sure it's working, and clean your IAC valve and the idle port in the throttle body with throttlebody cleaner.
You should find the procedure for this on this website.
Also, make sure you don't have vacuum leak.
Sep 23, 2008 at 1:02 PM
