Transmission fluid drains right out and will not engage?
350,000 MILES • AUTOMATIC
KIRK LAUGHHEAD
I was turning the corner, and I heard a loud pop then a cloud of burnt smelling smoke, then my transmission would not go into any gear. I pushed it into a station and was able to move it a little after I put in a quart of transmission fluid. I later put in four quarts which immediately drained out the bottom.
Oct 1, 2024 at 10:16 PM
  • 55,694 POSTS
It sounds like the transmission has suffered and major mechanical failure. The only was to tell for sure is to raise the car up for inspection. I would use a flashlight to help. This guide can show you how to raise the car up:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 2, 2024 at 5:16 AM
