Transmission fluid
159,999 MILES • 1.7L • 4 CYL • RWD • AUTOMATIC
AZA THAO
Where is the transmission filter located on my car? may i change it? And should I flush it if current fluid is black?
Aug 15, 2016 at 12:45 PM
SATURNTECH9
  • 30,869 POSTS
The filter is inside the transmission it is non service able it is just a fluid change. I would not flush the transmission. You can change the fluid then change the fluid a short time later again if you want.
Aug 15, 2016 at 12:58 PM
