1984 Honda Civic Clutch Slipping
DOMFAST2003
  • 12 POSTS
My 84 civic is starting to act up a little in the past few days since it got really cold and slick out. When im driving it everything is normal until you pull up a hill or give it alot of gas (Take off is real slow to) When you give it gas the rpm's just rise and it slowly moves. but if you take it slowly it will drive fine. it is a five speed and was just wondering if it could be the tranny fluid or something else. (I was stopped at a stop sign earlier and tried to see if i could even get the tires to spin or it take off fastly.....instead the RPM's rose and the car slowly pulled away)
Feb 17, 2007 at 9:15 AM
SERVICE WRITER
  • 9,123 POSTS
5-speed manual?- clutch worn
5-speed auto?- definitley check the fluid level, maybe too late.
Feb 17, 2007 at 9:33 AM
DOMFAST2003
  • 12 POSTS
[quote:3d3ce324c2="Service Writer"]5-speed manual?- clutch worn
5-speed auto?- definitley check the fluid level, maybe too late.[/quote:3d3ce324c2]
It is a 5-speed Manual........Would it be the clutch? the clutch really seems to work fine its just while driving. (Its Kind of like having the clutch pressed half way all of the time)
Feb 17, 2007 at 9:38 AM
SERVICE WRITER
  • 9,123 POSTS
It is slipping, it how it is described.
Feb 17, 2007 at 9:48 AM
DOMFAST2003
  • 12 POSTS
[quote:a62995528b="Service Writer"]It is slipping, it how it is described.[/quote:a62995528b]
What woulde you do to fix that? i have never delt with stick before
Feb 17, 2007 at 9:49 AM
SERVICE WRITER
  • 9,123 POSTS
HAve a new Clutch kit put in, I would expect $500-700? as a guess.
Feb 17, 2007 at 2:12 PM
DOMFAST2003
  • 12 POSTS
[quote:538dc4452f="Service Writer"]HAve a new Clutch kit put in, I would expect $500-700? as a guess.[/quote:538dc4452f]
It also smells really hot if you drive very much at all.
Feb 18, 2007 at 7:07 AM
SERVICE WRITER
  • 9,123 POSTS
Yeah it fits the symptoms too. Nice smell huh?
Feb 18, 2007 at 10:39 AM
DOMFAST2003
  • 12 POSTS
[quote:28bc74523f="Service Writer"]Yeah it fits the symptoms too. Nice smell huh?[/quote:28bc74523f]
Ya... Smells real good..lol.........I wish it was something less expensive......lifes hard sometimes though. Thanks for all the help.
Feb 19, 2007 at 5:39 AM
Suggested Repair
Have a new clutch kit installed. The symptoms match a slipping clutch; a rough cost estimate given was $500-700.
Conversation Summary
The owner of a 1984 Honda Civic 5-speed manual reported that under hard acceleration or on hills the engine RPMs rise while the car moves slowly, though gentle driving is fine. It also smells hot after driving. The expert said the clutch is slipping and recommended installing a new clutch kit, estimating about $500-700.
