Transmission disengages
120,000 MILES • 3.6L • V8 • 2WD • AUTOMATIC
JAMIE E THOMPSON
  • 5 POSTS
This is a old state trooper car. If I accelerate to fast the transmission will disengage until I slow down to about 15 to 20 miles per hour and then it will reengage and I can continue with the trip. I believe it is electrical.
Have any thoughts on this?
Apr 22, 2020 at 3:08 AM
  • 110,248 POSTS
Have you checked to make sure the transmission fluid is clean and full? This vehicle should have a transmission dipstick to check.
With the engine at operating temp and the vehicle on a level surface, start the engine and allow it to idle in park. Check the fluid level while it is running.
_______________
Next, if it is an electrical issue, there should be a diagnostic trouble code stored. Here is a quick video showing how to scan the computer for codes:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner,but often times a parts store will do it free of charge. I recommend having that done.
Apr 22, 2020 at 4:05 AM
