transmission fluid leaking
VBAUER
My 2007, Dodge Charger ST is leaking red, transmission fluid while parked. I began to notice this 2 days ago. The car is running well and I was wondering if this could be due to a change in the weather. It went from the 80's to 35 degrees over night....Is this possible?
Nov 24, 2007 at 7:13 AM
MERLIN2021
  • 17,250 POSTS
This car still under warranty? Run back to the Dodge boys! No it's not normal...
Nov 24, 2007 at 7:14 AM
VBAUER
Yes it is. I am planning on going Monday. Thank you.
Are there any danger signs I should watch for?
Nov 24, 2007 at 7:18 AM
MERLIN2021
  • 17,250 POSTS
If the fluid gets too low, you wount be able to move!
Nov 24, 2007 at 8:12 AM
VBAUER
Thank you for your suggestions. I am watching the fluid continue to leak onto the driveway.....not too happy about this little situation...
Nov 25, 2007 at 4:15 AM
LOUDCHARGER
[quote:cf4921308c="vbauer"]My 2007, Dodge Charger ST is leaking red, transmission fluid while parked. I began to notice this 2 days ago. The car is running well and I was wondering if this could be due to a change in the weather. It went from the 80's to 35 degrees over night....Is this possible?[/quote:cf4921308c]I have a 06 charger and i had the same problem. i brought it to dealer and it was the oring on the trans adapter plug. The whole problem was fixed in an hour.
Mar 31, 2008 at 12:07 PM
