Transmission crossmember
69CHEVYSTEPSIDE
  • 1969 CHEVROLET TRUCK
I'm having a hard time trying to figure out were I need to cut my old crossmember out of my truck for a new one because I'm putting in a automatic transmission but I have to cut out the old crossmember and put a new one in but I need to know where to cut the crossmember at to remove it.
Friday, April 19th, 2013 AT 12:55 PM
  • 52,797 POSTS
Post a picture.
You should match up the new crossmember to where you want to mount it
Friday, April 19th, 2013 AT 3:17 PM
HMAC300
  • 48,601 POSTS
The cross member should unbolt not have to be cut out. Besides you may just be able to put a different MOUNT for the automatic in first. You might check on powerblocktv. Com and look at one of the truck videos they did a few older restorations/customs and may lead you in the correct direction. It 's free and you can buy a video if you like that covers your vehicle or one that is similar.
Friday, April 19th, 2013 AT 3:22 PM
Related Transmission Replace/Remove Content
Automatic Transmission Replacement
VIDEO
