Transmission
124,578 MILES • 4.0L • 6 CYL • 4WD • MANUAL
19DANGERRANGER98
I have the vehicle listed above with a five speed transmission. will a transmission out of a 1994 4.0 4x4 five speed work?
Jun 6, 2017 at 9:26 AM
STEVE W.
  • 15,418 POSTS
Sorry, they are different. 1990-1997 are the same and 1998-2000 are the same.
Jun 6, 2017 at 3:30 PM
19DANGERRANGER98
What's the difference
Jun 7, 2017 at 9:45 AM
STEVE W.
  • 15,418 POSTS
Not 100% sure. Hollander lists that as a break year. It could simply be different sensor types when they did the upgrade in 98. I know they beefed up the M5OD-R1 to an M5OD-R1HD around 2000 because of multiple failures behind the 4.0.
OK - did a bunch of digging. Ford says the difference is where the speed sensor is. that on 97s the OSS is on the rear differential, 98 and later it's on the transfer case or extension housing. The sensors show different signal types as well so it isn't a matter of just changing the wiring as the TCM won't understand the different sensor.
Jun 7, 2017 at 2:55 PM
19DANGERRANGER98
Could I take the internals about of the 94 and put in the 98
Jun 8, 2017 at 12:18 PM
19DANGERRANGER98
The 98 4th gear went out
STEVE W.
  • 15,418 POSTS
Would probably work. You would need to get a parts sheet for both years and compare the numbers. It's a Mazda M5OD-R1 transmission.
Jun 9, 2017 at 8:31 AM
