Transmission When coming to a stop, it is very hard downshifting?
147,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
When coming to a stop, it is very hard downshifting. I think it is happening somewhere between second and fourth gear. It seems to happen more often when I am making a harder stop.
Aug 16, 2024 at 9:01 AM
  • 55,770 POSTS
Let's run the codes because it seems like you have an input shaft speed sensor (turbine) that is not working, or the value of the sensor has degraded. Also, can I ask if the engine power is normal? If not and the engine is down on power, you could have a partially clogged catalytic converter.
Here is a guide to help us:
This is the location of the turbine sensor in case you need it, also has the transmission been serviced lately. I would do this as well.
Here is a guide to help:
Transmission Fluid Type
5R55S .................... Motorcraft MERCON V ATF XT-5-QM
6R60 .................... Motorcraft MERCON SP ATF XT-6QSP
Capacities
Transmission Fluid
5R55S .................... 12.4 Quarts (11.7L)
6R60 .................... 11.2 Quarts (106L)
I have included the transmission service procedure for your car as well.
This guide can help as well:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Aug 17, 2024 at 2:51 AM
