Transmission does not have first, reverse or overdrive
260,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
THAMULL
It does not have first, reverse or overdrive.
Jan 29, 2018 at 12:18 AM
STEVE W.
  • 15,378 POSTS
If it is a 4L60E it could be a few things, most common for loss of those gears only = sun shell failure. Lo-reverse clutch pack worn out or blocked apply circuit to the piston.
Best option is a rebuild with a beast sun shell and heavy duty clutches. Next would be to replace with a remanufactured or used transmission depending on what condition the truck is in.
If it is a 4L80E the low and reverse band anchor pin is a likely issue. They can break or the case fails.
For both the losses can also be electrical and should show up on a good scan tool. It could be failed solenoids or bad wiring if that is the case. A good visual of the wiring and transmission connector and scan should show if those are the problem.
Jan 29, 2018 at 3:37 AM
THAMULL
Thank you. I had a buddy of mine who runs a local shop. The way he explained it was it was a common problem because we had snow and ice recently. He continues to tell me that water gets into the connectors for the transmission causing it to fail. I unplugged all connectors and cleaned them. Took the negative post off the battery for the night to reset codes. Did not work!
Jan 29, 2018 at 10:54 AM
STEVE W.
  • 15,378 POSTS
Water in them can cause problems. If he has a decent scan tool he can probably check to see if it is electrically related.
Jan 29, 2018 at 11:52 PM
