Engage
DONALDTR
  • 1991 FORD TAURUS
  • 3.0L
  • V6
  • 75,000 MILES
I have an AXODE that is dropping in and out of gear, by itself. It does it at ten mph and thirty five mph, varies. When it drops out, if I increase the engines rpm's. It will go into gear with a hard hit. The filter and fluid were changed less than a year ago. The fluid is full.
Wednesday, May 23rd, 2018 AT 1:02 PM
  • 52,797 POSTS
Good afternoon.
I would change the fluid and filter again.
Make sure you check the fluid level as well. If it is good and the filter is not clogged, you have internal issues with the transmission.
Tuesday, April 13th, 2021 AT 6:47 PM
