1996 Ford Taurus stalls and over revving
ROB CRAVEN
  • 1996 FORD TAURUS
  • 6 CYL
  • 162,000 MILES
1996 taurus intermittantly stalls on stopping or at low speed. Also, intermittantly over revving on accelerating from 1st into 2nd. Codes thrown are catallatic converter and O2 sensors. The 2 rear O2 sensors have been replaced but problem continues.
Mechanic thinks "computer" could be the problem but no way to test if "computer" is not working properly. Any suggestions are welcome!
Monday, June 22nd, 2009 AT 8:16 PM
  • 109,885 POSTS
Have you checked to make sure the converter isn't plugging up?
Monday, June 22nd, 2009 AT 8:56 PM
ROB CRAVEN
So the converter is pulled and examined? Correct? Is this an expensive job? Can the mechanic tell blockage if the problems are intermittant?
Thanks.
Monday, June 22nd, 2009 AT 9:13 PM
  • 109,885 POSTS
It can be pulled and inspected, or they can actually check back pressure from the O2 sensor ports. THey check pressure before the cat, and at the cat to see if there is a large difference.
Monday, June 22nd, 2009 AT 9:48 PM
