transmission
150,000 MILES
DFWAGS
Jeep works very sluggishly ( bogging down ) when put in drive. If I start in first/second, shift to third than drive it works fine. This problem just started happening. It was not slipping at all. Was wondering what I should go after first. Not sure if there is a sensor that I can test myself. Once I am going and in drive everything is fine.
May 17, 2013 at 4:27 AM
HMAC300
  • 48,601 POSTS
check trans fluid level first then have a trans guy scan for codes.
May 17, 2013 at 5:21 AM
DFWAGS
Thanks. I guess I should have thought of that.
May 17, 2013 at 7:14 AM
