Transmission
99,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
SAMUELOTOOGHANA
I changed my transmission valve body but when transmission fluid gets hot, the gears whine and does not change well. Oil level is fine and I used Xcel SP IV oil. Could it be any of the solenoids? Car works fine until it heats up. What could be the problem?
Jul 11, 2017 at 5:44 AM
  • 55,588 POSTS
Yes it sounds like you may have a bad valve body and the selector valves get hung up. You will need to take it back apart to see what happened. Can I ask why the replacement in the first place?
Cheers, Ken
Jul 11, 2017 at 9:39 AM
SAMUELOTOOGHANA
There was an oil leakage, clutch got burnt. I changed the drum, and then my mechanic tampered with the solenoids. It was not changing well so I was advised to change the valve body. Prior to this I changed the whole gearbox twice with used ones but they were all whining around the second and fourth gears. So I changed back to my old gearbox. I noticed my old one was working when I engage them manually but the moment I shift to automatic it begins to whine at the third and fourth gears. I was then advised to change the valve body which I did. That one drives perfectly but the moment the fluid gets hot, then it acts up.
Jul 11, 2017 at 1:42 PM
  • 55,588 POSTS
It sounds like you have an internal seal that has gone bad. It might be time for a rebuilt or low miles used unit.
Cheers, Ken
Jul 12, 2017 at 4:23 AM
