My transmission will not engage why - Does not go into gear?
54,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CHASEW3367
Well, when I put it in reverse it's like I have to give it a little more gas than usual to get it to start backing up. Like I can feel it catch then it's fine and sometimes it does the same in drive as well.
Feb 24, 2020 at 7:58 AM
Good afternoon,
I would change the fluid and filter. You may have a partially clogged screen in the pan.
Scan for codes as well
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Feb 24, 2020 at 8:28 AM
CHASEW3367
Is this something I can do or need a mechanic to do it?
Feb 24, 2020 at 8:30 AM
You can do this yourself. You will need to put it up on jack stands and get a large drain pan to drain the fluid.
Then release the pan and the filter will be inside. It just pulls down. The seal in the valve body will have to be changed as well.
Feb 24, 2020 at 8:40 AM
CHIP ATCHLEY
When I had it in cruise control at 45 mph. I stopped at light. When I went to go again truck was slow to take off even with applying more throttle. Around 15 mph it cleared up. On way home same day from work, it would only go 40 mph. Now it only goes about 20 mph and dose not shift to anything. Just stays in first as far as I can tell. Took to transmission shop. Drove it with computer hooked up and mechanic says it is commanding all the gears, 2, 3, 4 and is getting correct throttle response. They only work on internal parts and told me to take somewhere for wiring issues. So at home I disconnected the round grey plug on passenger side of trans. and it acts the same and still no codes except with plug unconnected the shift position indicator on dash is not illuminated.
So, frustrated, I went out and checked all connections again and pushed them in tight. Drove truck slowly at first and felt it shift this time into second. So kept going and when it went to shift into third it missed and tacked up like neutral. This was just in "D". So I stopped and started again in manual first. Then manual second and it hesitated and slid into second kinda mushy. So kept going and then manually into 3rd. Again it tacked up but I let off the gas and reapplied the gas and it caught third. So then I got it up faster and went to "D" and it went to "OD". Came up to light and stopped. Green light still in "D" and it was still in "OD" or High gear so I manually went to first and it shifted to first. Then manually to second and it went. Then manually to third and tacked up like neutral and I let off gas and re applied but it did not catch third. So I manually went to second and tried to shift to third again. This time it was trying to grab third, real slippy mushy so I let off gas and re applied and it caught third. Then it went to "OD". Kept going around came to light and had to do same scenario when light turned green. Basically had to do it every time I slowed down (manually shift). A few times second was slipping too but let off gas and reapply and it would catch. All shifts occurring around 2700 to 3500 rpm. By the time I pulled in driveway trans temperature was 256. It had been sitting two days prior to me doing this today.
Any thoughts?
4l60e Vin J
May 6, 2021 at 3:13 AM (Merged)
  • 55,562 POSTS
So the gear selector light are not lighting up? This is telling me the gear range sensor is out and needs to be replaced. here is a guide to help. This guide can help us fix it
CHIP ATCHLEY
Well, I got under the truck and removed the trans pan. Thinking I would replace fluid/filter and see if there were any shavings in the pan.I checked the trany dip stick previously as did the tranny shop. Mentioned wift of a burnt smell but nothing they thought was too too bad. Anyway so I pulled the pan and it was full of silver stuff and the fluid was black and smelled worse than from dip stick. Evidently the car lot I bought it from had been dumping the stuff in there to keep it running. I had the truck 2 weeks before all this started. No warranty, "as is" and I regret it now. I took a chance and it did not pay off. Now my son is looking for a 1500 and we will approach it much differently. I drove my truck to tranny shop (in one gear) and dropped it off. I grew up with this guy, same guy who put computer on it and saw it was commanding to shift. So, 1850 plus tax and a new hayden 1679 cooler, truck is running great. He told me the pump stater was broken and killed the input drum. Not sure if stater is right because it was a text and he actually said "stated" so im assuming stater but looked like a gear. See Pic. Think the gunk the guy put in it caused the no code. And I think the pump gear/stator broke on way to his shop. Just under $2,200 in all. He put the corvette servo in it and upgraded sun gear. Basically whole new planitary, which is in the kit i guess. Im not a transmission guy so dont hold me to it. :)
  • 55,562 POSTS
Yep that will do it, broken stater good find on that. Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
JLMEEK
My truck listed above will not go into gear. When I shift to reverse or drive it does not go into gear.
Good evening,
Did you verify the transmission level?
When was the last time you changed the fluid and filter? A clogged filter will do this.
Are there any codes set?
Since it is 4 wheel, does it go into any gear in any selection on the transfer case?
If all else is good, either the front pump or the torque converter has failed.
JLMEEK
I have he led the fluid. Looking at the bottom when trying to shift the gears below are not moving at all.
JLMEEK
I have checked the fluid and it’s good. The gears below are not moving when someone is shifting.
Do you mean the linkage is not moving at the transmission? That would indicate the cable has failed.
I attached the procedure for you and some pictures below for you.
3. Remove the clips on the cable from the floor panel reinforcement.
4. Ensure the transmission manual shaft is positioned in mechanical park.
5. Remove the retainer that secures the cable to the bracket.
6. Remove the cable clip on the transfer case, if equipped.
7. Remove the range selector cable end (2) from the transmission range selector lever ball stud (1).
8. Depress the tangs and remove the cable from the bracket.
9. Lower the vehicle.
10. Ensure that the steering column shift lever is still in the park position.
11. Remove the drivers seat. Refer to Front Seat Replacement - Bucket .
12. Pull back the carpet and insulation around the driver's area.
13. Remove the instrument panel knee bolster. Refer to Knee Bolster Replacement (with RPO SLT) Knee Bolster Replacement (without RPO SLT) .
14. Remove the retainer securing the cable to the steering column.
15. Remove the cable end from the steering column ball stud.
16. Depress the tangs and remove the cable from the steering column bracket.
Important: Avoid unnecessary twisting/bending of the range selector cable when removing the cable from the support.
17. Remove the range selector cable from the support.
18. Remove the cable grommet from the floor panel.
19. Remove the cable from the vehicle.
JLMEEK
How much would this cost?
BBANDERSON
I have the truck listed above (SS model). I was driving it one day, and it acted like I put it in neutral with a bang. Now if I put it in a gear I have to keep revving it up like to build pressure and it starts driving, then its like I lose pressure again.
Good evening.
How long has it been since you changed the trans oil/filter? A clogged filter will cause this issue.
The cable is about 100.
The labor is 1.2 hours or around 125.
BBANDERSON
I have not yet. I just bought the truck maybe got three hundred miles out of it. Fluid looks a little brown but not bad.
Okay, it should be a nice red color. I would start there and change it a couple of times. When you change it you just drain the pan. you still have seven or eight quarts in the converter that does not come out.
That is why I would do it again after about 1,000 miles.
BBANDERSON
Okay, I will give it a try thanks.
KELLIS
Light comes on but doesn't engage?
Sounds like a plan before we start talking about internal transmission issues.
  • 55,562 POSTS
It sounds like the pressure control solenoid has gone out here is a diagrams showing the location and the removal. You we need to remove the transmission pan this guide can help.
JT007
Hi, I saw you talking to another guy about his truck I kind of have the same problem, but not I just installed a new transmission into my truck and the tires aren’t spinning after I installed the drive shaft it spins when I turn the tires but won’t spin freely like the transmission isn’t disengage it.
Okay, thanks.
The transmission is not going into gear.
Did you use a rebuilt or used transmission?
Did you change the filter and fluid?
KAWISTUNTZ
  • 7 POSTS
Was driving completely fine transmission never got over 200 temperature. no weird noise or anything. get home 2 hours later I go to back out of my driveway and does absolutely nothing, but everything else runs good.
Good morning,
How long since you changed the filter and fluid?
With no gears, it could be either the filter is clogged, a torque converter failure or the front pump.
KAWISTUNTZ
  • 7 POSTS
Changed filter few months back and maybe 6 weeks ago changed the fluid. when I did shift solenoid A fluid was clean no metal shavings or anything.
KAWISTUNTZ
  • 7 POSTS
I never got to change the second sensor which is B and it's a pressure sensor, but I still had reverse when it was throwing that code. could it possibly be the pressure sensor finally gave all the way out? but if that was the case wouldn't every gear be acting up from lack of pressure?
No, I doubt it.
Are there any codes set? If it was a sensor, it would code.
I would still change the filter and fluid.
KAWISTUNTZ
  • 7 POSTS
I have not taken it anywhere since I found those sensors were bad the two shift solenoids right under the pan like I said. I changed one solenoid A it said the other one was bad as well, but didn't have the part yet. so I know for a fact solenoid B is still bad and you really believe it may be the filter? it's only 5 months old and have changed fluids twice since then. A few weeks ago when I had the pan off again the filter looked new still.
KAWISTUNTZ
  • 7 POSTS
But the transmission temperature has never been over 200. didn't hear anything last time I used reverse few hours before it went out. still no odd noises. is there any other sensor for the transmission besides those two shift solenoids?
KAWISTUNTZ
  • 7 POSTS
Even when those two solenoids were reading bad on code reader no lights on my dash came on and still haven't. my ABS and brake light one kicks on at same time at least once a day, but i figured that wouldn't relate to my transmission.
None that will not allow it to go into gear.
If the filter is not your issue, it is internal. This is a mechanical issue, not a sensor issue.
RAMP2010
My truck shifts into all gears, I can hear it but it doesn't move. It will inch forward but then stops. It feels as if the brakes are locked. I tried all gears and my truck starts to move but again it feels as if the brakes are preventing it from moving. I check my front and rear brakes and none of them are locked up. I even tried putting my truck in neutral with my truck off,and still nothing.
Correct. The ABS is a separate issue.
When you say you can hear it shift into gears do you mean you can hear the shifter engaging? More then likely you don't have proper internal transmission pressure.
I would suggest we start with checking for proper pressure when putting into gear.
Also, can you try putting it one of the manual gears? Meaning shifting to 3,2,1 and not just drive and see if it moves in one of these gears. If not then it is most definitely a pressure issue so we should start there.
Let me know what questions you have. Thanks
KAWISTUNTZ
  • 7 POSTS
Okay, thanks for the help. I have to replace that last solenoid anyways so I'll pull the filter and clean it and hopefully that is it. I just feel it's too new still and had two sets of new fluid since then. but then again it doesn't take a lot of debris to throw them off.
RAMP2010
Thank you for responding. I have spent hours Googling for some clues. Here's the thing: I can shift it into all of the gears and i have tried shifting into 1, 2, 3 and the truck feels like it starts budging forward, however it just stops like it has the parking brake set. I'll proceed to replace the pressure tap plug. Thanks again. I really appreciate you taking the time to respond.
You cannot clean the filter. Replace it.
You are welcome.
Always glad to help.
You are welcome. However, I just want to clarify that the pressure tap plug is for you to put a pressure gauge in it and test the pressure in the transmission. I highly suspect you have low or no pressure which is why your vehicle is not moving. Let me know if you have questions. Thanks
