When I press the gas engine just revs there is no movement
236,900 MILES • 6 CYL • 2WD • AUTOMATIC
MARKSAK
Left a parking lot. Backed up fine and got me to the street fine, turned and pressed gas to accelerate, engine revved but did not accelerate. Drifted into another parking lot, car won't move on its own. I can move the gear shift, engine sounds as if it's shifting, but when I press the gas, just revs, no movement. When I shift back into park it makes clank sound of metal hitting metal for a second. Know the car isn't worth much, just wondering if I should scrap it or if it's something cheap and easy like the solenoid to get fixed? Please advise.
Oct 23, 2019 at 9:49 AM
STEVE W.
  • 15,408 POSTS
Welcome to 2CarPros. Your description sounds like it could be something external to the transmission. The clanking you mention sounds like the parking lock trying to engage as the internal parts stop. I would probably do a quick test by putting the truck in park and with no brakes on see if you can push or pull it. If it moves in park there is a mechanical failure. Possibly a U-joint or something inside the transmission. If it doesn't move in park but still will not move under power then start checking farther. First check the transmission fluid level. You will want to see nice clean red fluid. Black or worse black with metal or grit means the transmission is probably in need of a full rebuild.
Oct 23, 2019 at 2:04 PM
MARKSAK
Thank you. It can be pushed when it's in park. Is the u joint or something inside the transmission an easier repair? The transmission fluid was definitely dark, and low on the dip stick. Got some and filled it, no change.
Oct 23, 2019 at 6:54 PM
STEVE W.
  • 15,408 POSTS
As it can be pushed in park the first area to check would be both of the front drive axles to see if one has failed. To do that you need to get the front end in the air enough to see and feel the front axles and have the tires off the ground. Then you can look and see if all of the parts of the axle turn when you move the tire. If everything moves and you can grab the axle and it doesn't have free play or obvious damage the issue is more likely internal, either a failed drive chain or a broken shaft. If one of the shafts has damage like a failed boot and you can hold the inner axle joint and the wheel turns then replacing the half shaft would repair it.
Although not your vehicle this is the same basic method to replace one.
https://www.2carpros.com/articles/replace-cv-axle
Oct 23, 2019 at 11:17 PM
