2005 Ford Escape eratic rpm
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
WCONVERSE
When driving at between 50 and 60 miles an hour,
I let up on the gas and the rpm drop and come back
up then drop and come back up several times. I tried one time to put the car and neutral and the rpm did
not drop all the way down. I had the code checked
and no codes are showing?
Jun 7, 2010 at 10:28 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 7, 2010 at 10:30 PM
