Transmission does not engage in drive
150,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
STASH72
Drive does not engage, reverse engages, park engages.
Mar 6, 2018 at 5:49 AM
good evening.
If reverse works but no forward, there is a either a clutch failure or drum issue inside the transmission for forward clutch system.
There is nothing external that can cause this. it is a mechanical failure inside the transmission. it will have to be removed and inspected for the failure.
Mar 6, 2018 at 7:19 AM
