Transfer case
132,000 MILES • 5.2L • V8 • 4WD • MANUAL
TIREGUY79
  • 35 POSTS
when locked in it drives fine until you put power into it you can hear it pop or slip is it the chain or both chain and sprocket and what years of dodges will fit it in case I need a used one
Sep 9, 2016 at 2:13 PM
SATURNTECH9
  • 30,868 POSTS
We're talking about the transfer case correct?
Sep 9, 2016 at 11:27 PM
TIREGUY79
  • 35 POSTS
Yes for the 4wheel drive
Sep 10, 2016 at 2:35 AM
SATURNTECH9
  • 30,868 POSTS
Without looking inside its hard to say what's wrong with it.Also there is two or 3 different ones.Would have to know the tag number on the transfer case and I could look up what years that tag number is interchangeable with.
Sep 10, 2016 at 10:07 AM
TIREGUY79
  • 35 POSTS
Ok will look at the tag and let you know
Sep 10, 2016 at 10:39 AM
SATURNTECH9
  • 30,868 POSTS
OK sounds good
Sep 10, 2016 at 11:11 AM
TIREGUY79
  • 35 POSTS
It's a 231 d and my truck is a manual transmission and also will Durango or Dakota work I see they have same transfer case so if you can find out if any other makes or models and years will work that would be awesom
Sep 15, 2016 at 8:59 AM
SATURNTECH9
  • 30,868 POSTS
Is the truck a 1500 or a 2500
Sep 15, 2016 at 11:30 AM
SATURNTECH9
  • 30,868 POSTS
If it's the 1500 then only the dodge ram 1500 pick ups from 1998-2001 will work.The actual tag number Iam talking about is a lot longer number the the one you gave.That's the transfer case code number you gave me.The other number I wanted was called the motor tag id number.But no matter which tag number it is still going to be the pick up only 1998-2001
Sep 15, 2016 at 11:35 AM
TIREGUY79
  • 35 POSTS
Ok well thank you I was looking and some 2000 Durango have same one but they are all automatic
Sep 15, 2016 at 12:57 PM
TIREGUY79
  • 35 POSTS
Would you know where to find one by chance
Sep 15, 2016 at 12:58 PM
SATURNTECH9
  • 30,868 POSTS
Rock auto dot com has them
Sep 15, 2016 at 1:07 PM
