transmission problems
157,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BOOSTBOSS
While I was driving my van suddenly jerked and what seems to be in neutral. It will go into gear but will not engage or move. I recently did a transmission flush and notice small pieces of metal. There was no damage from what I could see. Not really sure about transmissions please help. Thank you for your time.
Mar 12, 2018 at 12:53 PM
Good morning.
It sounds like the torque converter has failed. I had two of these and had the same failure on both vehicles.
I suggest a transmission shop to be sure that is the issue. if that is the case, then the transmission will have to be removed and inspected.
Mar 12, 2018 at 8:19 PM
