Transmission issue
188,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JEFF JONES8
When driving it shifts okay until fourth or fifth gear then it hangs and overdrive button has no effect. if you shift it manually you can feel it into drive. I think it is a five speed with overdrive.
Could I please have a guesstimate?
Thanks, Jeff
Jan 7, 2018 at 6:20 PM
  • 55,710 POSTS
It sounds like you have a transmission shaft speed sensor for the transmission that is not working or a little off. Can I ask if you have run the codes? Here is a guide to help you do that so you can report back and we can go from there:
Cheers, Ken
Jan 9, 2018 at 6:11 AM
