Hi CamryOwner03,
Thank you for the donation.
From the description of the noise, it should not be anything serious and nothing to worry about.
Noise are never easy to detect and being intermittent makes it more difficult. From the symptoms, I believe it is caused by a vacumn valve. The internal diaphragm of the valve is vibrating and emitting the noise.
The next time problem occurrs, shift to neutral and rev up engine slightly to test. If noise level changes with engine speed, that would most likely confirm it to be vacumn related.
Does noise goes away after changing to lower pitch?
Wednesday, September 2nd, 2009 AT 1:01 PM
