Transmission swap
153,450 MILES • 3.2L • V6 • 2WD • AUTOMATIC
PAULA FOSTER
Please list compatible transmissions from other vehicles.
Nov 28, 2019 at 5:21 AM
STEVE W.
  • 15,413 POSTS
From the information I can find the 2003 and 2004 Isuzu Rodeos use the same transmission but no other vehicles interchange with that because of them having the 3.2 engine and they stopped building them in 2004 and they switched to a different transmission in early 2003. If you have the earlier build with the GM 4L30E in it there still are limited options because of the 3.2 and being 2WD.
However both transmissions have rebuild kits for them and most internal parts are available.
What is the issue with the one that you have that you wish to change it?
Apr 5, 2021 at 6:35 AM
PAULA FOSTER
Lower gear tines sheared and throwing metal shavings , major slipping. I have to manual shift in order to even move truck . Also the transmission pan has severe leakage which was not resolved by changing gasket.
PAULA FOSTER
the transmission is also not the original correct transmission. it is currently a 4 cylinder Jasper transmission, and my truck is a V6. Not sure how these fools who did this thought it would work out.
STEVE W.
  • 15,413 POSTS
The internals are almost the same but almost doesn't count for much in this case as they are geared different. I would find a true transmission shop, they should be able to rebuild your transmission using the correct parts for the V6. Or build one even stronger.
