As per the instruction from Isuzu if you are having problems moving the shift lever from P while hitting the brake with the engine running, then move the key switch to ACC position also move the shift lever from P to N position and start the engine. Why?
That is the problem I am having
Peter Lindstrom
Peter Lindstrom
Aug 31, 2008 at 3:31 AM
