2003 Toyota Tundra Air Bag light is on
2003 TOYOTA TUNDRA
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
DONICAS
I took this newly acquired truck to a dealer to check it over and find out why the air bag light was on. They said the truck needs a spiral cable and sensor assembly to make the bags work again. There estimate was $850 incl labor.
I then went on the internet to get a quote from a well respected independent mechanic (I have never used them). He said he thinks I must be referring to a "clock spring assembly" that goes in the steering column. His quote is $330.
My question is do you think they are talking about the same part? I would hate to spend $330 and then find out the problem isn't repaired. On the other hand, I hate to spend $850 if I can get the same job for $330.
Jul 29, 2009 at 10:25 AM
  • 31,937 POSTS
Hi there ,
If you can give me the fault code i can tell you what the problem is, post it here. you will need to get a scan do to get the code.
mark (mhpautos)
Jul 29, 2009 at 4:14 PM
DONICAS
Where do I find the fault code? I don't want to take it back to the Toyota shop unless I am getting it repaired there...they've already charged me $55.00 dollars just for looking at it. (They said they would apply it to the repair).
What I need to know is the spiral cable and sensor assembly the same part as the clock spring assembly.
Thanks
Jul 30, 2009 at 1:27 AM
  • 31,937 POSTS
Hi there,
yes these are the same part, it's just that here we only refer to it as the clock spring, i had never heard of it being referred to as a spiral cable & sensor, just a case of different terminology for different country's.
mark (mhpautos)
Jul 30, 2009 at 1:47 AM
DONICAS
thank you for the information
Jul 30, 2009 at 1:54 AM
