1995 Toyota Tercel No #1 Compression
CHRCHLL129
I have noticed my 1995 Toyota Tercel (160,000 mi) missing so I took it to the shop after I replace all the plugs and wires. My check engine light was on, and the mechanic said I have no compression in my #1 cylinder. For full repair I was looking at around $500.00. I only paid $800 for the car so I do not want to put that much in at once. Is there an easy fix to see if I have a small problem resulting in the lack of compression (what problems cause no compression)? (anything I can test, or other problems that would lead to no compression in a cylinder.) If not how much of a project is it to do myself. Im not a licensed mechanic but pretty mechanically inclined. Any help or info is much appriciated.
Jul 16, 2007 at 2:08 AM
  • 75,988 POSTS
[quote:699f535be0="chrchll129"]I have noticed my 1995 Toyota Tercel (160,000 mi) missing so I took it to the shop after I replace all the plugs and wires. My check engine light was on, and the mechanic said I have no compression in my #1 cylinder. For full repair I was looking at around $500.00. I only paid $800 for the car so I do not want to put that much in at once. Is there an easy fix to see if I have a small problem resulting in the lack of compression (what problems cause no compression)? (anything I can test, or other problems that would lead to no compression in a cylinder.) If not how much of a project is it to do myself. Im not a licensed mechanic but pretty mechanically inclined. Any help or info is much appriciated.[/quote:699f535be0]
Do a cylinder leakage test to identify where the leakage is coming from.
Jul 16, 2007 at 8:36 AM
Suggested Repair
Perform a cylinder leakage test to identify where the compression leak is coming from.
Conversation Summary
The owner of a 1995 Toyota Tercel with 160,000 miles reported a miss and check-engine light after replacing the plugs and wires. A shop found no compression in cylinder 1 and quoted about $500 for repair. The owner asked about possible simple causes, tests, and DIY difficulty. The expert recommended a cylinder leakage test to locate the leak.
