1995 Toyota Tercel Overheating and White Smoke
183,000 MILES • 4 CYL • FWD • MANUAL
MYLIK23
Yes, I have a question in regards to my 95 terecel. I Purchased the car 2 years ago (used of course), with approx. 176,000 miles. The car ran fine for the first year. Then last year Dec 2006, car overheated, in which I practically rebuilt the entire engine. Replaced the head gaskets, water pump, timing belt. It ran fine for another year. And this past December, the fan went out, which resulted in the car overheating (again). So, I replaced the fan. And today, the car is making a noise, the oil light flashes on and off (more on when the air conditioner is running) and I noticed white smoke coming from under the hood as well as underneath the vehicle. Also, when the car is shut off, the coolant from the radiator goes back in the reservoir in which it bubbles. I don't know too much about cars, but what can this be indicating? Thanks in advance.
Jan 2, 2008 at 6:03 AM
  • 75,988 POSTS
Could be the headgasket blown/ radiator cap/crack head/block. Get it block or pressure tested to check for combustion gases in the cooling sysem.
Jan 3, 2008 at 6:25 AM
  • 55,684 POSTS
Hmm, it sounds like you have a cracked cylinder head, did they check the head for cracks when it was off? This guide can help confirm the issue.
and
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Dec 18, 2024 at 9:03 AM
