1994 Toyota Tercel Oil Burning
1994 TOYOTA TERCEL
280,000 MILES • 4 CYL • 2WD • AUTOMATIC
PRANEEDH
  • 5 POSTS
From last October it seems my car is burning oil a lot.
I don't see any oil leaks. But small oil traces are seen between the gasket and head towards the distributor side.
I use 10 w 40 oil. I replaced the oil filter in December 2008. Buy now it has used 8 liters of oil and I had to fill again yesterday.
What could be the cause? and the how to repair it?
If this is normal for this model and mileage, can this be fixed by using High Mileage oil?
Mar 3, 2009 at 1:58 AM
BLACKOP555
  • 10,386 POSTS
280000 miles, good god thats alot of miles.
do you have blue exhaust? chances are your piston rings are just about shot or the valve seals are. let me know if you have blue exhaust or what.
Mar 3, 2009 at 4:10 PM
PRANEEDH
  • 5 POSTS
There is no blue smoke.
Mar 4, 2009 at 12:45 AM
BLACKOP555
  • 10,386 POSTS
is the only oil leakage you see on the heads? how much is there? any puddles on the groudn where vehicle is parked overnight?
Mar 4, 2009 at 12:47 PM
PRANEEDH
  • 5 POSTS
The only oil leakage I see is on the heads towards distributer side. It is also just a oily look. no drops of oil falling down.
By the way I closly monitored the smoke.There is litte blue smoke in the morning.
I changed the oil to Hi-Milage 10W 40 yesterday.
I will monitor how fast this oil gets burn for the next few weeks.
Mar 11, 2009 at 9:10 AM
BLACKOP555
  • 10,386 POSTS
blue exhaust definetely indicates burning oil. could be a host of problems youll have to check. let me know what you find before we continue.
Mar 11, 2009 at 2:42 PM
