1994 Toyota Tercel oil consumption
1994 TOYOTA TERCEL
18,000 MILES • 4 CYL • FWD • MANUAL
PHG
My car has started using about 1 quart per 300 miles, I realize this probably a ring problem. what checks can I make and can a ring piston job be done with out removing engine
Thanks Paul
Mar 8, 2008 at 12:58 PM
The only way to confirm it is do a compression and cylinder leakage test. could be valve seals/stems/guides/valves/rings/-
Its a small engine take it out cleanliness is the enemy in engine rebuilding-BTDT many moons.
Mar 13, 2008 at 8:44 PM
