1991 Toyota Tercel starting problems
CHARLES R PINKSTON
  • 1991 TOYOTA TERCEL
  • 4 CYL
  • 126,000 MILES
Subject car has 1995 motor. Has strange starting problem. Will start and run perfect. Next time will not start, will allow to set for a day, will attempt to start, no luck, may try again in a day will not start. Next time it will start. Has repeated this dispite replacing plugs, wires, dist cap and rotor. Also have added injector cleanor. Sometimes it acts as if it was flooded and other times not.
Friday, February 15th, 2008 AT 10:23 AM
LEGITIMATE007
  • 5,121 POSTS
Check connections for corrosion and test alternator and let me know what happens
Saturday, March 1st, 2008 AT 10:01 PM
