1989 Toyota Tercel Electrical Failure
SPONJAHGIRL
Help! I don't know what to do about my 1989 Toyota Tercel. The engine is a 1.5L SOHC 4-cylinder with 112,694 miles. Recently, the tail lights, instrument panel, blinkers, window wipers, and radio would stop working while I was driving and then come back on after a little bit. Then my car wouldn't start sometimes. I fixed that problem with a little button, and everything seemed to fine, but the other issues came back and are actually much worse. Now nothing comes on at all, total bummer. I thought it might be the alternator since the charge battery light kept flickering on, but after testing with a DMM, and the fact that my headlights are still going strong, I ruled that out. I've also noticed that the fuse box on the driver side holds everything that happens to be malfunctioning. The fuses seem fine and I even tried pulling them all out to test if one might be faulty. Could I be wrong and it is the alternator? Or is there a bad wire or connection? If so, where I should I look to fix it and how? On a side note, there's a couple of curious things. The radio will come on when I turn the key, but as soon as I push the button to start my car it doesn't work anymore. Also, if I go really fast on the freeway, sometimes the gas gauge will work, as well as a few other things...for a moment at least. :cry:
Jul 10, 2007 at 11:01 PM
  • 75,988 POSTS
[quote:f7d1496fdd="sponjahgirl"]Help! I don't know what to do about my 1989 Toyota Tercel. The engine is a 1.5L SOHC 4-cylinder with 112,694 miles. Recently, the tail lights, instrument panel, blinkers, window wipers, and radio would stop working while I was driving and then come back on after a little bit. Then my car wouldn't start sometimes. I fixed that problem with a little button, and everything seemed to fine, but the other issues came back and are actually much worse. Now nothing comes on at all, total bummer. I thought it might be the alternator since the charge battery light kept flickering on, but after testing with a DMM, and the fact that my headlights are still going strong, I ruled that out. I've also noticed that the fuse box on the driver side holds everything that happens to be malfunctioning. The fuses seem fine and I even tried pulling them all out to test if one might be faulty. Could I be wrong and it is the alternator? Or is there a bad wire or connection? If so, where I should I look to fix it and how? On a side note, there's a couple of curious things. The radio will come on when I turn the key, but as soon as I push the button to start my car it doesn't work anymore. Also, if I go really fast on the freeway, sometimes the gas gauge will work, as well as a few other things...for a moment at least. :cry:[/quote:f7d1496fdd]
This button I assumed is for the starting circuit. I will test the ignition switch it sounds like its going whacko!!
Jul 28, 2007 at 10:26 PM
Suggested Repair
Test the ignition switch. Intermittent loss of the tail lights, instrument panel, blinkers, wipers, and radio, along with starting problems, suggests a failing ignition switch rather than the alternator or fuses.
Conversation Summary
The owner of a 1989 Toyota Tercel with a 1.5L engine reported intermittent failure of the tail lights, instrument panel, blinkers, wipers, and radio, followed by occasional no-start and then a complete loss of those circuits. Headlights remained strong, a DMM test seemed to rule out the alternator, and the related fuses appeared good. The radio worked with the key on but stopped when the starter button was pressed, and some gauges briefly worked at high speed. The expert advised testing the ignition switch.
